Probably a bad question, but new here, how do i make a custom size cornice e.g. 90, 100, 50 cove?
Hi user30,
There are two options I can recommend (depending on the desired outcome & PlusSpec version you have), which I’ve outlined below.
Option 1: Currently the size of cornice cannot be adjusted &/or created, so if you want to have different profiles & sizes I could recommend drawing the profile(s) in your model using SketchUp tools & then using the
Custom Estimation Tool to apply an estimating material to each length of cornice.
This is explained in a little more detail in the post linked below.
Option 2 (PlusDesignBuild Only): You could create a material for each profile that’s named differently so that is appears differently in the takeoff (this is for all version & not just PlusDesignBuild), however, you can also use the override items feature in the takeoff to specify all variations of cornice you want/need. This eliminates the need to create multiple materials (that - in this instance - would just be name changes), so you won’t need to redraw the geometry if a different cornice profile needs to be specified.
Tip: This method can be reused in multiple other areas of the takeoff to save you time.
I believe we are working on a solution/tool/upgrade that enables more sizes?
