Hi, I am trying to create a soil volume in a model to transfer to the BOQ and price. The area is 600 sqft, and the depth is 5", but every time I create a BIM item based on the slab’s floor area and then select UOM as cubic—including adding 5" to the measurement—I get 0.417ft3.
Hi Gareth,
I’ve had a look into this & the reason it’s appearing as 0.417ft3 in the takeoff is because 5" is 0.417ft. Since your Dialog Units are set to “inches” & Takeoff Units are set to “feet”, the value is being calculated. The value that needs top be entered into the Size field is the total amount of that object (e.g. if it was a 2ft x 2ft x 2ft cube, then 8ft should be entered).
Usually I’d say select the object & then look at the Volume listed in the Entity Info to get the value to enter into the Size field, however, in this case it appears it may not be the correct value (according to the measurements you provided & your screenshot - i.e. 255.62ft). Note: If the Volume field doesn’t appear in Entity Info, it means that SketchUp cannot calculate a value for the selected object as the geometry is the geometry is flat/2D or is broken in some way (aka the geometry isn’t manifold).
In this instance the value you’d need to enter into the Size field is 432000" or 250ft (depending if you want to enter inches or feet). Tip: Length fields will always calculate to the specified dialog units, so you can you enter any size & unit you like.
Another method to achieve your desired result, which should hopefully be quicker & easier for you, is to use the
Custom Estimation Tool to get the volume quantity of the object/geometry. I responded to your other post with info on this which may be helpful (see link to post below).
Hi Grant,
I haven’t used the custom estimation tool yet, so I will also give that a go and see how it differs from the method Mitch suggested. I think the issue with the BIM tool is the “illustration” in the help button—I assumed it was the length “X,” which needed to be inserted; in my case, that was the depth of the material. I now understand how it works, but maybe the help tool explanation.
Gareth.
The custom Estimation Tool is the right tool for this.
Hi Gareth,
Thank you for the feedback regarding the field help image. I’ll take it back to the development team for further discussion & see if we can make the field help image explanation clearer. ![]()
