When using single masonry with cladding structure won't show in scenes
Every time I use single masonry with cladding and I try and see the structure everything will disappear. Am I doing something wrong with it or how can I fix that?
Hi user84,
You’re not doing anything wrong, the structure scenes only show structural framing by default.
If you want to see the masonry you’ll need to turn on the following tags/layers (under the 2 Walls folder in the Tags section of the Default Tray) & then update the scene (right-click on the scene tab & select Update). Note: You’ll need to do this for each scene & model.
  • 19A_BRICKWORK
  • Brickwork
  • External Walls
It’s the scene you are in. Click :see_all: in the PlusDesignBuild or PlusArchitect main menu, or, as Grant says, turn the tags you wish to see on. Tip. Once you have the settings you like, right-click the scene and select ’ Update ’ or ’ Create New Scene. This way, you’ll be prepared next time. You can also use File > Save As Template to save this setting for next time.
