Is there a way to generate roof geometry with fascia and soffit elements shown correctly as elements with depth (thickness) β instead of simple planes?
Just to add context, the attached is a detail from the tutorial demo model provided.
Hi KADO3D,
Roofing geometry can be draw with a thickness via one of the following methods.
Note: For either method I would recommend drawing the roof but selecting βnoneβ for the materials. This way you can use the roof geometry to trace around or create the geometry from (depenidng on the method used).
