We’re look at improving estimating from IFC files imported into SketchUp via the IFC Tool. The goal is to generate a more in-depth BOQ so that you can use it for construction estimation & ordering without redrawing a Revit model. In the future, we’re looking at SketchUp geometry being parametric within Revit & Revit geometry being parametric with PlusSpec tools.
However for now, we’re specifically looking at delivering a square (area) takeoff for cladding, flooring, roofing, etc. (we use SketchUp Studio in our office, which allows you to import Revit files directly, however we understand most of you are using the older perpetual versions of SketchUp (i.e. SketchUp 20 & before)).
We’ve done a lot of research yet if you have anything you’d like to see added, feel free to let us know.
By the way, if you’re looking at doing an estimate of the above, use the Custom Estimate Tool.
I know many of you receive IFC, Revit & ArchiCad files, but are you using them to price quote and order materials? Or are you just using them to trace and detail yourself in PlusSpec?
Any feedback would be great.
If I put my builder hat on, i see distinct time saving and deciphering advantages in using an IFC file, especially when overlaying the structural steel & engineering details.
The other advantage of using an IFC file is the architect or building designer retains the intellectual property associated with in house Family and GDL coding. This makes it easier to get a file. The IFC will capture the information PlusArchitect & PlusDesignBuild use to automate the process to deliver usable models. The functionality will reduce your time redrawing and and increase the accuracy of assigning costs, recipes and ultimately quoting.
