Multi skin wall issue
I am having an issue with a multi skin wall when I extend it , it creates a copy but only extends the framing and not the exterior cladding or interior lining. Any Ideas?
Multi-skin wall re-define issue
Stan
Hi Stan,
I was able to replicate the issue for that wall in the model you send across. However, when I created a similar wall in that model or in a new SketchUp file I was able to redefine walls as normal (which is odd).
I’m not sure what’s causing the issue with redefining that wall but the development team have said there’s something they need to fix, which we will work on getting released as soon as possible. In the meantime, I would recommend deleting & redrawing that wall it in the model (which should work).
