Hi
I am not able to use the I beam tool both in the platform setting and in the manual install. When i try to install manually and double click to end it just continues without closing. In the platform setting, it just does not work, all other profiles are fine, just the I beam profile.
This same issue also affects the guys in the engineering department with thier application of Plusspec.
I am working in it now, I don’t have the same issue. Do you have an error coming up in the ruby console?
I also do not have this issue. Is anyone else getting it?
@user45, what version are you using and is it happening on PC or Mac?
