How do you add exterior window trim? It looks like it automatically did it for one window in my project (or I did it and have no idea how). Any help is appreciated. Here’s a quick screenshot.
In the window tool under casing. Options are none, 1 side, 2 sides.
Ok thank you appreciate that. Other question related to that. Why does it turn on off with the roof tag/layer?
Hi JP,
The exterior window trim is currently on the same tag/layer as the roof (i.e. 21_EAVES) because it’s normally installed at the same time as the eave/soffit lining. This should only be the case for windows & external doors.
To assist with your original enquiry, you can go to the Settings Tool & can change how the trim works. By default it’s set to adjust via the wall type (i.e. one side for external wall types & double sided for internal wall types) but you can change it to remember whatever the last input you selected was (like how the rest of the software works).*
