After drawing the walls I can’t see the location of the window and door openings on the plans
Hi ConT,
This may be due to the section plane being above the window & door openings. If you move the section plane down into the correct position it should fix your issue.
If this isn’t the case, can you please provide some more info & a screenshot of the issue? Thanks.
