Watertable assistance
I have a house with the front facade wall consisting of external cladding and a stone watertable. The watertable is roughly 30" tall and the cladding then continues from top of stone to the roofline. What is the recommended way to create this type of a wall? Go into each wall and edit it? I’ve had problems where I add or delete a window and it completely resets the wall. Suggestions?
The best way to do this is to draw your water table wall at 30" high using the cladding as the construction type. Once drawn then go back and adjust your height for your new wall.
Once all options in the wall have been selected, you can then go and draw your wall on top of your watertable wall.
This will stop any problems with windows and still estimate and look correctly.
