Hi, AusSketch You can do it inside the wall tool :wall-tool: , by choosing a Skillion or Gable wall. or you can do it manually using the :redefine-wall: tool. it is more accurate doing it inside the wall tool using raked or gable wall settings, here is the tutorial video youtu.be/toAA6jJMyME Or see instructions below:
This works on sloping rooves, so if you need a gable draw it twice with teh sloping/skillion roof tool.
Here are the steps
- draw multiple walls
- draw a sloping/ skillion roof over the walls
- Select both the walls and the roof
- Right-Click the walls and roof and select extend walls to roof
- Select if you want the cladding to go all the way to the roof or have it level.
