Wall Tool
Trying to create an External timber wall with 1/2" ply on both sides. I can create a 1/2 ply material for the outer face but when trying to create a 1/2" plywood material for the inner face the thickness field is missing on the create new material page. How can I create an external timer frame wall with 1/2" ply on inner and outer faces?
Hi JBMI,
There was a slight bug on the Create Material page where the thickness field didn’t appear. This has been fixed up now so you should be able to create your wall type.
I would recommend using the ‘Internal Only’ wall type as this way you’ll only need create the material once.
