Hello, I’m hoping someone can send me in the right direction with an issue I’m having with sketchup 2024. The wall tool is buggy and won’t make changes to walls that I request. Dimensions are also out - when I change the cavity width of a double brick wall, the result will be different to my input. Any assistance would be much appreciated! Thanks
Hi Brendan, let the office know if the following does not work for you. I’m working in imperial and I don’t have an issue with the latest version.
Have you pushed sync
, if not, try that. We did update some materials in the latest release, so you may have speced a material that changed name.
If this does not work to Go to Extensions>PlusSpec>Restore factory default
