What if costing info gets changed midway through a project?
I may be wrong but I believe that the only way to modify cost info is via the BIM Tool.
If this is true, then couldn’t there be a Modify [size=150]Model BIM[/size] attributes dialog?
A user could select any one BIM attribute (in this case costing info) and then go through the entire list for that attribute, modify the data, and then click an apply button to update the applicable BIM objects.
If the BIM attributes would be in a columnar layout and then perhaps there could be also be a sort function by clicking on the title heading of a column.
