Update Information
Latest release: v1.3.35 (20th Oct, 2014).
To be notified of new releases, subscribe to this topic.
Latest version can be downloaded from https://buy.plusspec.com/download. Mac/OSX users need to use the RBZ installer (help using the rbz installer).
>>> Platform Support Table
               Sketchup 8   Sketchup 2013   Sketchup 2014   Sketchup 2015
  Windows      No           No              Yes             Yes
  OSX (Mac)    No           No              Yes             Yes
Windows users should update to the lastest Internet Explorer version available.
This is available from the following link: windows.microsoft.com/en-us/inte … ownload-ie .
To check your current version:
  • Open SketchUp
  • Open Preferences Menu
    [list]
    [*] On Windows, this is under the Window menu
  • On Mac/OSX, this is under the SketchUp menu
    [/:m]
    ] Click Preferences[/:m]
    ] Click the Extensions option[/:m]
    ] Click the PlusSpec option[/:m]
    ] The current version will then be displayed below the extension description.[/*:m][/list:u]
Minor releases may not be listed here, but the changes will be listed as inclusive in the appropriate patch notes.
b[/b] → v1.2.0 (9th May, 2014)
  • Add: Split Wall
  • Add: Merge Walls
  • Add: Plugin Settings now available in Plugins > PlusSpec > Settings
  • Update: Change TNC/EULA from Beta conditions to release conditions
    [list]
    [*] You may read the updated terms at https://buy.plusspec.com/plusspec-prerelease/terms
[/:m]
] Update: Interactive Tutorial for new tools and layout[/:m]
] Update: Default values for tools[/:m]
] Update: Various Dynamic Components[/:m]
] Update: Some tools will now show status bar messages[/:m]
] Update: :wall-tool: alignment can now be changed using the [kbd]RIGHT[/kbd] key[/:m]
] Update: Drawing a slab from face will now make the surface area equal to that fo the face[/:m]
] Fix: Launch issues when using SketchUp 2014[/:m]
] Fix: Installer will no longer install ruby unless it is needed[/:m]
] Fix: Various internal issues[/*:m][/list:u]
v1.2.0v1.3.0 (30th May, 2014)
  • Add: :wall-tool: now has basic tooltips
  • Add: New Roof Tool ( :roof-tool3: )
    [list]
    [*] Rewritten from scratch
  • Supports split level roofs
  • Old roof tool still available by using the :roof-tool: icon
    [/:m]
    ] Add: Roof Pitch Tool ( :roof-pitch-tool: )
  • Roof generated using the :roof-tool3: can have the pitch of any face altered
    [/:m]
    ] Add: USA Package now available
  • See downloads section at https://buy.plusspec.com
    [/:m]
    ] Update: Wall dimensions now read left-to-right looking from the outside in :window-tool: and :door-tool: [/:m]
    ] Update: Distribution now contains source for requirements, this should make installation faster[/:m]
    ] Update: Terms and conditions have changed. Check https://buy.plusspec.com/plusspec-prerelease/terms for new terms[/:m]
    ] Fix: Sill timbers will now have the correct orientation[/:m]
    ] Fix: All roof entities will now be layered correctly[/:m]
    ] Fix: Removed redundant message when license is missing[/:m]
    ] Fix: :bim-tool: will now reject characters that will break DC processing[/:m]
    ] Remove: :wall-tool: no longer has bisector override[/*:m][/list:u]
v1.3.0v1.3.1 (10th June, 2014)
  • Add: OSX (Mac) Support
v1.3.1v1.3.3 (26th June, 2014)
  • Add: Layer Selection option in :bim-tool:
  • Fix: Debug code causing some dialog issues on Windows
  • Fix: Some path issues in OSX
  • Fix: Numerous internal changes
v1.3.4v1.3.5 (3rd July, 2014)
  • Add: More Stair components
  • Add: Generic roof cappings for slate and tile roofs
  • Fix: A number of issues with USA materials
  • Fix: Layering issue with stair components
  • Update: Scene generator layers and styles
v1.3.5v1.3.6 (4th July, 2014)
  • Fix: Roof fascia and capping issues
v1.3.6v1.3.8 (9th July, 2014)
  • Add: version to toolbar (note: removed in v1.3.10)
  • Add: Context menu entries for roofs
  • Add: Context menu entries for windows and doors
  • Add: Fibre Cement
  • Fix: Roof estimation issues
  • Fix: BIM Tool needlessly updating definition name (@JClements)
v1.3.8v1.3.9 (10th July, 2014)
  • Fix: Web Dialogs get stuck on “Loading” when using IE 8, 9 and 10
  • Fix: Roofs returning to original position after redraw
v1.3.9v1.3.10 (10th July, 2014)
  • Fix: Toolbar un-docking after updating
v1.3.10v1.3.17 (28th July, 2014)
  • Add: More context menu entries for some entities
  • Fix: Stud Timber now has a default when using the USA package
Also includes various other internal changes.
v1.3.17v1.3.27 (1st Sep, 2014)
  • Add: Take Off will now use localised units
  • Update: Garage door components
  • Update: Remove unused textures
  • Fix: Inconsistent roof position when using context menu
  • Fix: Some components not saved for SketchUp 8
v1.3.27v1.3.35 (20th Oct, 2014)
  • Add: Help button on toolbar :help-tool:
  • Add: New materials
  • Add: New debug information generator
  • Add: Help tool-tips for some tools
  • Add: Rectangular concrete option in :post-tool:
  • Add: Ability to change origin in :post-tool:
  • Add: Window options
  • Add: Wall Surface Tool
  • Update: Metric units should be more uniform
  • Update: Scenes
  • Update: :bim-tool: notes are now optional
Also includes various other internal or minor changes changes.
