Hi there !
Last saturday I decided to test Plusspec (v21.4). It was until the wall tool didn’t work at all. Finally I reinstalled everything after erasing all plusspec files and it worked until today.
I think I have a problem with Framing, because this problem came when I changed some parameters of Stud Timber and when I created a new material.
So I decided to erase everything, like the first time, but with the new version v21.6. I also tried to restore factory default, but nothing better.
Still stuck !!
All other tools works perfectly
Any idea ?
For information :
Sketchup Pro 21 Version 21.1.331
Plusspec v21.6.0 stable
Debug file :
{“sketchup”:“21.1.331”,“plusspec”:“v21.6.0-stable”,“extensions”:[{“name”:“TNT_ClickChange”,“version”:“1.1”,“author”:“David”,“loaded”:false,“load_on_start”:false},{“name”:“PlusSpec”,“version”:“v21.6.0-stable”,“author”:“RubySketch”,“loaded”:true,“load_on_start”:true},{“name”:“Outils de caméra avancés”,“version”:“1.3.4”,“author”:“SketchUp”,“loaded”:true,“load_on_start”:true},{“name”:“Composants dynamiques”,“version”:“1.8.1”,“author”:“SketchUp”,“loaded”:true,“load_on_start”:true},{“name”:“Outils Bac à sable”,“version”:“2.3.1”,“author”:“SketchUp”,“loaded”:true,“load_on_start”:true},{“name”:“Trimble Connect”,“version”:“2.0.8”,“author”:“SketchUp”,“loaded”:true,“load_on_start”:true}],“environ”:{“USER”:“fctm”,“PATH”:“/usr/bin:/bin:/usr/sbin:/sbin”,“LOGNAME”:“fctm”,“SSH_AUTH_SOCK”:“/private/tmp/com.apple.launchd.FTDCLLrbBn/Listeners”,“HOME”:“/Users/fctm”,“SHELL”:“/bin/zsh”,“__CF_USER_TEXT_ENCODING”:“0x1F5:0x0:0x1”,“TMPDIR”:“/var/folders/l1/8jw1g_112j95nbmn3thrt7tw0000gn/T/”,“XPC_SERVICE_NAME”:“com.sketchup.SketchUp.2021.13868”,“XPC_FLAGS”:“0x0”,“IG_ROOT”:“/Applications/SketchUp 2021/SketchUp.app/Contents/Resources”,“GEM_PATH”:“/Users/fctm/Library/Application Support/SketchUp 2021/SketchUp/Gems”,“GEM_HOME”:“/Users/fctm/Library/Application Support/SketchUp 2021/SketchUp/Gems”,“SSL_CERT_FILE”:“/Applications/SketchUp 2021/SketchUp.app/Contents/Resources/Content/Tools/cacert.pem”,“RLM_DIAGNOSTICS”:“/Users/fctm/Library/Application Support/SketchUp 2021/liclog.txt”,“RLM_ROAM”:“”,“SQLITE_EXEMPT_PATH_FROM_VNODE_GUARDS”:“/Users/fctm/Library/WebKit/Databases”},“ruby”:“2.7.2”,“now”:“2021-11-27T16:26:33+01:00”,“useragent”:“Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) SketchUp Pro/21.1 (Mac) (Mac; Safari)”}
