Hi All
Looking at purchasing Plusspec. I have a perfect small job to start the learning process. One question, does Plusspec cover timber pile construction. All the examples I have seen are concrete slab foundations.
Cheers
Jonathan
Hi All
Cheers
Jonathan
Hi Jonathan,
You can 100% use timber pile construction with PlusSpec.
Mainly here in Australia we use concrete slab foundations but we can also use block and beam, timber and others.
Hi Jonathan,
Just to add to Dean’s Post… PlusSpec is basically totally cutomisable so not only can you build a timber (or concrete) pile floor system you can also include all your tie downs (pile fixings), joist hangers, damp coarse elements etc. These can all be priced and will appear in your “takeoff.”
Zorro
