textures /materials
There are a lot of textures that i’ve got from the public user created library i can’t use.I did update and sync but still it won’t work.
Hi joedol,
Thank you for your post and my apologies for the delay in the response to your enquiry.
The Public User Material Library has all materials separated into sections for the different areas in PlusSpec so that if you select and download Masonry Wall materials then they should appear where the masonry materials are in the Wall Tool.
I haven’t come across this issue before. When you say that you can’t use them, do they not appear anywhere in PlusSpec or do they download but can’t be selected and used in the material fields?
