How do I add a customized structural steel in Component
tipes: say a hollow swction column 200x200mm.?
T.i.a. Leonardo
Hi Leonardo,
You aren’t able to currently add components to the Component Tool, however, if you follow the steps below you can achieve a similar result.
- Draw the desired component, with the correct size & materials, in a new SketchUp model.
- Select the component then use the PlusSpec BIM Tool to add the product info so it will appear in the takeoff.
- Save the SketchUp file in a folder on your computer. Note: If you save it to a shared drive, anyone who has access to that drive can also use the component.
