Hello,
I just downloaded the trial of PlusSpec to try it out.
Is there a way to build walls that have steal framing?
Thanks.
Hello,
Thanks.
Hi Seven,
In the Wall Tool & throughout PlusSpec you can create your own materials, so if there’s something missing that you want or need you can easily create it. All you need to do is click the ‘Create’ button under the material field, enter the material info & either drag-and-drop the material or use the Sync Tool to to get the new material(s).
Hope this helps! ![]()
i got it, thank you for the explanation.
