Hi all,
I’m doing some early concept pricing with tiltup panels, I’m using 8m panels. The issue I’m finding is that I can’t seem to stack voids vertically (either multiple door/window voids or a mixture).
I’ve tried coping one of the openings and stacking manually, which works, until I edit the copied void (the lower void has a 300mm higer head)… it disappears as soon as I touch it.
The closest I can get is using SU rectangle with push and pull and voiding, it leaves an annoying strip at the threshold but fine.
Just wondering if it really needs a work around or I’m missing something?
Dan
