Slab connectivity to walls
If you have already drawn your slab, and then you adjust the walls - do you have to delete the old slab, and then re-draw a new slab? It would be great it the slab was smart enough to adjust in size and shape, along with the connected walls.
Note: Same as above for Roofs.
Regards,
dp
For the moment, that is the case. This kind of automation is, however, a planned addition.
