Hello,
My Skillion Roof tool is no longer working. It just gives me a roof face and 1 side face. Also, for the other roof tools, Is sheathing, vapor barrier and insulation suppose to be flat faces? This is how they appear with no depth and I havn’t found info on this. I also need to know how to do an eave on just a short portion of a side and was assuming that I could do this with skillion but its not working for me.
We recently released v23.3.0 which has changes to the Skillion Roof Tool. Can you please update to this version & let me know if the issue still occurs?
Using the Ctrl key whilst drawing skillion roofs will enable/disable overhangs for each side of the roof. If you go to the orange ? icon in the dialog there should be a video showing how to do this.
There is also a new feature in the new release that allows the eaves around skillion roofs to be individually adjusted after they’ve been drawn.
I have installed the updated version and the skillion tool still not working. I am familiar with the tool as it was working the first few days after my first installation of the program.
The next thing I would suggest doing is to restore your factory default. To do this go to Extensions > PlusSpec > Restore Factory Default & then select OK when the dialog appears.
If this doesn’t resolve the issue can you please open the Ruby Console (Extensions > Developer > Ruby Console) & then replicate the issue. If a message appears in the dialog can you please send it to us?
