I watched plusspec before and miss the video to set all walls at same level can you guys help me
Hi nguyen,
Thanks for your post!
There is a tool called the levels and layers tool in PlusDesignBuild that enables you to choose a starting height for all geometry that you select, if this is what you are referring to, however this feature is not available in PlusSpec Pro.
From what I can tell in this image you’d just have to ctrl + select the walls that are sitting at the wrong height and move (M) them to the right height.
Does this answer your question?
Emily
