Just learnt that if you group your model your section hatching does not work, after trying many things i realized i grouped the model. I exploded and un grouped and the section hatching worked as usual… I have also had trouble when i played around with the active cut, this can also impact the section hatching…
In the current version the Section Hatching Tool won’t work through groups or components but in the next version you will be able to. The next version should only be a couple of weeks away.
When you were playing around with the active section what were the steps you took and what was the result?
