Section Hatching issues
I am having some issues with the section hatching.
  1. I get some walls that set the hatching at the section cut and others that place it at the base of the wall?
thanks
Im. Pretty sure you’ll find that all walls have the hatching at the base.
@TruLine Your issue looks like you’ve used single brick walls in combination with double brick?
Maybe the issue is the single brick wall hatching texture?
You could test it by drawing one or two single masonry walls and re running the section cut hatching tool.
