it seems like there is something going on with the section hatching. I haven’t done a lot of exploring yet, but when I try to place a hatching it makes one big blank field that blocks out everything. Has anyone encountered this yet?
Dawson
Dawson
Hello Dawson, I just came across this today myself, I have brought it to the attention of the dev team. Thanks for pointing this out, it appears to be a Sketchup 19 compatibility issue as I just tried running a live section in Sketchup 18 and it works fine.
Hey Dawson, I hope you are using the PlusSpec 19 version, it is 10 times faster. If not, you can get it at the sign-in page, here is the link https://buy.plusspec.com/users/sign_in
Hi there, wondering of there is any word on that hatching tool? I am using version 19.1. I have starting doing my hatching by hand or in Layout which is fine, but Plus spec should be doing it…
Thanks!
Hi Dawson,
We are currently making changes in and around the Section Hatching Tool which will be in one of the coming releases. I believe these changes will improve your experience with section hatching & Layout.
HI there,
Just updating to say that I’m still having the section issue. Doing a front section in this case, it just makes a big solid plane that doesn’t include the section of the object(s). It doesn’t seem to be an issue from every perspective. I’ll see if I can narrow it down…
Dawson
I’m also having problems with Section hatching. Seem to constantly get a large grey face appearing within the section plane once I hit “Create section hatching”. I end up deleting this face as it obscures the whole model.
Hi again,
I am having this problem again today. I haven’t for a while, but now here it is again. I’m not sure what’s different on my end (beyond and new machine/ clear slate)
Has anyone else seen this issue recently, or have an idea what’s up?
EDIT: Upon further exploring, underneath the big blank filed is a useable section hatch. Easy enough to delete the big one, but why?
Cheers,
Dawson
Hi Dawson,
Without looking at the model & trying to replicate it I’m not sure why it’s happening, but it is odd. Would you be able to please send the model across to info@rubysketch.com so I can look into it further?
