It would be good if a comment or drop down is added especially for new users regarding creating of roofs by drawing or by selection… When you use the “Roof Tool” to create a roof you are unable to edit this roof at a later stage. The right click selection do not recognize the item as a roof? This is very limiting, It would not be as bad if you were at least able to select the parameters if you need to repeat that roof.
regards
This is explained in our tutorials.
Both roof tools draw a ceiling if selected. If you then have to edit your roof and you have drawn it using the normal roof tool and not the face roof tool, all you have to do is delete all of the roofs components except for the ceiling. You then select the ceiling and create the roof from the face. This will then make the roof editable.
We have future plans to fix this.
