I’m trying to build my house with my floor plan imported into the program. However, i’m having issues with the roof for the back of my house. Can someone help? Needing to know what to do to get the roof straight when walls are not the same height.
Hi mlclayton,
Thank you for your post & my apologies for the delayed response.
When creating a roof that has different walls heights you normally need to create faces at the different heights and then merge/join them into each other. There are a few tutorial videos in the link below which explain this in more detail may help with the issue you’re having.
https://www.youtube.com/playlist?list=PLNRcN-A1tOEz3iu9YZ1H0lSyiKzcSM9qF
If you’re still unable to get the roof to work after watching the tutorials, would you be able to please send the model to support@plusspec.com so I can have a look at it? Thank you in advance.
