Roof Edit Tool
I am having a problem with the roof edit tool in the US version. I create a hip roof from a face and the roof is built just fine. I use the “roof edit tool” to change to a gable and it does create the gable but it looses the fascia, soffit and gutter along both sides of the building. See attached images. I also noticed in the Roof Edit Tool that the gable overhang is still in mm.
Hi Scott,
Thanks for the Bug Report!
I’ve just tested this on my own version with the same Result!
We’ll work on a solution to this and update you when it’s resolved!
Dan
Hi Scott,
Just letting you know that we have resolved this issue and the updated version will be live shortly and available to download.
I will post here when it’s ready!
Dan
Work great!
Thanks Dan
Good to hear!
I’ve just had a look and there’s a few little problems i can still see with it - If you pick up anything else let me know - But i’ll have the other things I’ve found fixed ASAP :slight_smile:
Dan
