recess/ledge tool remove
Hi Guys
Using the new remove ledge/recess tool, but the recess is still showing.
Myles
Hi Myles,
I’m not quite sure where this issue is occurring. Can you please send a screenshot of the result you’re getting and the result you are trying to get?
Hi Grant,
I’m trying to remove the ledge around my slab, one have of my slab needs the ledge for bricks but the other half just has cladding.
Myles
Hi Myles,
If you’re drawing the slab from points you can press the ‘Ctrl’ key and it will toggle the recess/ledge. This feature was only just added in PlusSpec 17.
If you’ve already drawn the slab or created it from a face, I would recommend to use the Void Tool (right-click on the slab and select ‘+ SLAB > Void Tool > Add Void’) on the recess/ledge you want to remove.
