Hi Team,
Would it be possible to have a “raked” window option… I see it working in a similar principal to how one can specify the angle on a gable or skillion wall.
Zorro
Hi Team,
Zorro
Hi Zorro,
Currently this isn’t possible with the Window Tool, i do think it would be a good idea for it to work as the Wall tool does with Gables / Skillion walls.
I’ll add it to the suggestions list!
Dan
Another vote for adding a angled window feature to the window tool. I have a project I could be using that on right now.
If you check the component tool, you will notice that there is a Dynamic Raked Window that can be used. The is also a Skillion Window.
They are very cool and are easy to use. They also estimate.
