Hi, I need to add 6mm ply bracing to external walls and can not find how to do it. Am I missing something?
I thought that there would have been an option to add a component such as external ply bracing in the wall options, given that is not an uncommon wall configuration.
Here is how to add ply bracing to a wall in PlusDesignBuild. Note: you can also add cross bracing or tension bracing by selecting the bracing type required according to the wind loads of the project.
Right Click a wall
Select +Walls
Click +bracings
Click Insert bracing
Choose your bracing type
Left Click on the wall to select the starting point of your Sheet/ply bracing
Left-click on the wall to select where you want your bracing to finish
