Hi there
This is an easy one that hopefully can be added in the next version.
It would be really handy to be able to specify Plate sizes either 35mm or 45mm.
Whether it be Top or Bottom or Ribbon.
It would also be a good idea to be able to decipher between a top plate & a ribbon plate [an additional plate directly above the top plate] & be able to make them 35mm & 45mm respectively which is common practice here in the ACT.
Hi Jamie, thanks for responding, from what I understand you would like the ability to have a 9045 bottom plate and 1, 2 or 3 3590 top plate in the one wall?
We are working with walls over the next few weeks particularly with double headers, whilst we are there we will look into the top and bottom plate sizes.
Thx Andrew
Yes, A typical LB wall profile we work with is 35mm Top & Bottom Plates & a 45mm Ribbon Plate [directly over the top plate] This allows greater flexibility in truss/rafter setouts.
