I am having trouble with some PDF files that I import in, basically the plan loses its measurements and also has random black shapes over the plan.
This error only really happens to me on floor plans but not the elevations from the same plans… Does anyone know why this might happen or a way to fix it?
This might be due to the PDF file you’re trying to import as there are multiple variations of PDF files. What I would recommend trying is to make sure that you set the ‘Import Quality’ field to a better setting (i.e. Best) and then importing the PDF.
