I like to put these nib walls at an entrance. How can I finish a PlusSpec wall end here? I could model up some trim and architrave but I like these plastered with ex-angles. Any suggestions?
Hi Arnold,
What I would recommend to do is to either manually edit the plasterboard to return around the end of the wall (edit the base geometry of the plasterboard) or do do what you said and model up some trim and fit it in with the wall. Please note that if you make any changes to the wall using a PlusSpec tool any manual edits will be lost.
Thanks Grant, yes, I clicked in and edited the plaster and it looks much better.
