Materials
Hi, When i’m creating a new wall i don’t have all the selections of bricks that are available.
How do i rectify this.
Gerard
Hi Gerard,
I’m not quite sure what’s happened but here’s what I recommend to try.
  1. Go to the Settings Tool (Extensions > PlusSpec > Settings) and ensure that the ‘Material Library’ and ‘State’ (only currently appears for the Australia library) fields have the correct option selected.
  2. Sync you materials using the Sync Tool.
If the brick you’re after still isn’t appearing I would recommend to create a material.
Hi Grant,
Thanks for the reply, your solution solved my problem.
Cheers,
Gerard
