There should be no problems running Windows 8.1 on a Macbook if you are running a licensed version of Bootcamp.
This could be 2 things. The first could be that you have not used PlusSpec for more than 7 days. As security for your account PlusSpec will automatically log you out and make you log back in and this popup will appear. When this pop up appears, log in using your PlusSpec login and then a new page will appear. When the new page appears click the red button that says ‘Activate/Reactivate’.
If you do press Activate/Reactivate and an error appears it means that you have a Machine ID error. This is when your machine ID has changed since the last time you used the software. Can be caused by changing internet connection (for Mac). For Windows this is very rare. If you do have this issue email me explaining what is happening and I will give you a solution.
