Issue when exporting/importing recipes or vendor info – software freezes
Hi everyone,
I’m having a recurring issue in PlusSpec. Whenever I try to export or import any recipes, or when I modify vendor information, the software freezes completely. The only way I can continue working is by closing and reopening the program each time.
Has anyone else experienced this problem? Do you know what might be causing it or if there’s a fix/workaround?
Thanks in advance for your help!
Hello @Drafting_G1
I have not heard of this. What version are you using, and how long has this been happening?
@Grant, have you heard of this?
Hi Drafting_G1,
I also haven’t experienced this issue before. I just tested several parts of the takeoff that can import & export but I didn’t come across any issue as well. Below are some questions I have regarding your issue.
  1. Does it happen when importing, when exporting or for both?
  2. Which recipes are you trying to import/export?
  3. What vendor info did you modify or try to modify?
  4. Does it happen for small models (e.g. just one wall)?
Would you also be able to please send a video to support@plusspec.com showing the issue & steps you took to get it? It may shed some extra light on what could be causing the issue. Thanks in advance.
