That is all.
Hi Rubicabprojects,
When you set prices for materials, you can select measurements from a drop-down to the right of the supply and install boxes. Currently, the drop-down allows you to choose mm2, cm2, m2, feet2, inch2, as well as mm3, cm3, m3, feet3, inch3 (depending on the construction/material type).
