How To Add Bearers To Joist and Add Steel Joists
I have been asked how to add bearers and use steel joists a few times now and so I have done a quick step by step tutorial below on both.
Adding bearers to joists.
  1. Draw your face
  2. Click the face so that the face is highlighted
  3. Open your joist tool
  4. Select your joist type and other options.
  5. Open ‘Bearers Options’ and tick the box that says ‘Enable Bearers?’
  1. Select your bearer type and beam size.
  2. Click submit and your done
How to change to steel joists
    1. Draw your face
  1. Click the face so that the face is highlighted
  2. Open your joist tool
  3. Go to joist type and a drop down list will appear, Select the ‘Steel’ option
  4. Choose your spacing
  5. Select either Beam A or B
  6. Click on submit
You may also want to check the drawing location from the face, it is at the top. Basically you can have the joists start from the top down when drawing or the bottom up.
I understand a lot of people are used to drawing top down, plan views in 2d view, especially when doing joist layouts. That is no problem, simply click the structure tab. It is easy to create joist layouts in PlusSpec and add in the associated trimming beams or annotations.
I’ll make a video if it is of assistance?
Hi Andrew. Thanks for meeting with me today. I would like a video of how to make steel joist.
Here is a image of what I’m looking for. Also, i would need to ablity to make changes to the sizes (depth, width and length) when needed.
Good to meet you, Michal, I briefly went through this with you in our meeting sorry, I had back-to-back meetings, so it was rushed, but if you go back through the recording you’ll see how. In Short, Use the truss joist option in the joist tool and click Create material. This is the best way to change the size and the name & size
