Where can I learn how to customize materials for example brick walls? I’m Dutch so I selected the UK library. I need to make several walls:
single brick wall 100mm
single brick wall 110mm
double brick wall with isolation 100-170-100mm etc.
Does every material need a texture?
I have textures myself but can’t find how to use them within the Plusspec material editor https://minecraftbedrockapk.com/. It says drag and drop, but it doesn’t work.
