Hi guys,
I’m trying to trim the external wall(masonry) to the roof truss while maintaining the height of the studs (which supports the truss).
Is this possible? or should I just manually trim it using pushpull tool?
Thanks!
Hi guys,
Thanks!
Hi user29,
Yes this is possible. If you go to the Cladding/Lining Overrides section of the
Wall Tool & enter a value in the External Clad Drop Off field you can adjust the external skin (see image below). Tip: A positive number will drop it down & a negative number will extend it up.
Note: You can also adjust the bottom of the external skin via the External Clad Step Down field.
