Hi, quick question re gable roofs from a new user.
I’ve drawn the roof now needing to convert to gable ends.
Following the tutorials is suggests to left click to select roof then right click for the drop down menus however I don’t get the edit roof selections?
I only get the standard Sketchup selections. I’m using an iMac so is it slightly different to tutorial?
Cheers Matt
Hi Matt,
There is a simple reasoning to this. The right-click options only appear if you create a roof using a face. If you manually draw the roof you will not be able to edit the roof.
Using an iMac is no different to windows when it comes to roofs.
Send an email to dean@rubysketch.com and I will give you more information on this.
Thanks for the quick response.
I found the solution. I was actually left clicking on roof rather than the right…
Cheers
Hi Matt,
Good to hear ![]()
Enjoy!
