I am having this bug when trying to create doors ( see Below ) , I am using the latest version of plusspec and windows 11
Good morning Adam,
We’re not able to replicate the issue. Would you be able to send the model to info@rubysketch.com so the development team can look into this issue further
Hi Adam,
I’ve had a look at the model you sent across & found what the issue is. For some reason the Door Thickness field has been set to a large value for this door, but there is a way to resolve it which I’ve explained below.
Note: I saw in the model you used the Custom Door Tool to get around this issue, so you should be able to remove this door now.
