Extension not working, error unassigned
Extension Errors Report
SketchUp: 24.0.553
OS: Windows 11
Ruby: 3.2.2
Extension: PlusSpec (v24.4.0-stable)
Error: NoMethodError (undefined method flush' for #<Enviz_SketchUp_Plugin::Enviz_Logging::LogProxy:0x000001e034e6dcf8 @log_array=[], @original_stream=#<Sketchup::Console:0x000001e034efac48>, @log_file=#<File:C:\Users\MichalCatari\AppData\Roaming/Enviz_SketchUp_Plugin/Logs/plugin_log_2024-08-10_06-19-03.txt>>) C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/forwardable/impl.rb:4:in compile’
C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/forwardable/impl.rb:4:in _valid_method?' C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/forwardable.rb:213:in _delegator_method’
C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/forwardable.rb:189:in def_instance_delegator' C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/forwardable.rb:159:in block in def_instance_delegators’
C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/forwardable.rb:157:in each' C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/forwardable.rb:157:in def_instance_delegators’
C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/psych.rb:730:in singleton class' C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/psych.rb:712:in module:Psych’
C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/psych.rb:234:in <top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require’
<internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/yaml.rb:4:in <top (required)>’
<internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require’
C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/yaml/store.rb:5:in <top (required)>' <internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require’
<internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' c:/users/michalcatari/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rubysketch_plusspec/plusspec.d/estimation3/file_system.rbs:3:in ’
c:/users/michalcatari/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rubysketch_plusspec/plusspec.d/development.rbs:6:in eval' c:/users/michalcatari/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rubysketch_plusspec/plusspec.d/development.rbs:6:in require’
c:/users/michalcatari/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rubysketch_plusspec/plusspec.d/development.rbs:6:in <main>' c:/users/michalcatari/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rubysketch_plusspec/rubysketch.rbs:59:in eval’
c:/users/michalcatari/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rubysketch_plusspec/rubysketch.rbs:59:in require' c:/users/michalcatari/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/rubysketch_plusspec/rubysketch.rbs:59:in ’
C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:93:in eval' C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:93:in require’
C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:93:in block in <top (required)>' C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:31:in gracefully’
C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:43:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require’
C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load' C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec.rb:47:in register_extension’
C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec.rb:47:in <module:PlusSpec>' C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec.rb:26:in module:Rubysketch’
C:/Users/MichalCatari/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/rubysketch_plusspec.rb:25:in `<top (required)>’
Hi Sara,
The reason for this error is because there’s a conflict with another extension. If you go to the Extension Manager & disable the Enviz SketchUp Plugin (it may have a different name) it should resolve the issue & you’ll be able to use the PlusSpec software.
@SaraAdmin24 In this situation, please give Grants instructions before posting, as the end user will get a result instantly.
The following screenshots show how to do it.
