I come up against this quite often where a door opening is partly in the foundation. I have been working around it by splitting the foundation wall, or like in this case, adding a course to the foundation wall broken at the doors. It gets the point across, but as you can see doesn't carry the door all the way down. The line at the second course of masonry is distracting as well. Do you have any suggestions for this?
There’s currently no ability to extend the bottom of the door. I have taken this back to the development team for further discussion.
Regarding the horizontal wall edges showing, in the next big update there will be changes to this which will improve the visualisation of stacking walls on each other. Until then I would recommend splitting the walls vertically where the doors are located and drop the height of the walls below the doors. This will remove the extra lines.
Would you be able to please let me know if the above works for you?
