When i try to generate 3D i get the error message - "autocad export audit error : check “audit report.txt” for errors.
But that file is gibberish. Can someone please help me. thanks
This tells me you have imported a DWG, but the file did not import. I am guessing that the file is corrupt. Have you tried exporting for AutoCad as a previous version? Riley, you need to add a bit more information for us to be able to help.
Also, if you have a PDF, you could use Inkscape to convert it to a DWG. Inkscape is free and is an excellent way to import a vectorised PDF. Here is the tutorial https://youtu.be/QdVxwahy_V8?si=KM5POLdySL0dR-8a
