"Error Loading File" - sha2.so Error
If you launched SketchUp and this page was shown there is an issue with your plusspec installation. Further information follows.
Here’s an error we’re seeing a little too often for our liking. In this thread we will make any information we have on this issue available for people experiencing this issue.
The error itself occurs when starting SketchUp 2014, shows the follow error message:
"Error Loading File C:/Users/redacted/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec/initialize.rb
Error: #<LoadError: 127: The specified procedure could not be found. - C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific/digest/sha2.so>
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/digest/sha2.rb:13:in `<top (required)>'
C:/Users/redacted/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:64:in `block in <top (required)>'
C:/Users/redacted/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:30:in `gracefully'
C:/Users/redacted/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:49:in `<top (required)>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `load'
C:/Users/redacted/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec.rb:38:in `register_extension'
C:/Users/redacted/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec.rb:38:in `<module:PlusSpec>'
C:/Users/redacted/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec.rb:25:in `<module:Rubysketch>'
C:/Users/redacted/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec.rb:24:in `<top (required)>'"
Current Status: We’re looking into this issue and have alerted the SketchUp guys of it’s presence.
Current Advice: Update the the latest possible version of plusspec (14.1.1282 as of 9th July 2014). If you are continuing to experience issues, using SketchUp 2013 should allow you to continue using plusspec.
If you are experiencing this issue, you may wish to:
  • Subscribe to this thread for updates
  • Post a reply here stating your OS (Windows version, 32 or 64 bit) and any other plugins you are using
We appreciate your patience while we resolve this issue.
Can anyone suffering from this issue tell me the response from pasting each of these (individually) into their ruby console (Window > Ruby Console?)
Sketchup.find_support_file("Tools")
require "digest/sha2"
puts $:.inspect
File.exists?(File.join(Sketchup.find_support_file("Tools"), "RubyStdLib/platform_specific/digest/sha2.so"))
require "digest/sha2.so"
Could you also post the version of SketchUp your are running (as shown in Help > About SketchUp)
Thanks.
Error message after first line
Sketchup.find_support_file(’Tools’)
Error: #<NameError: undefined local variable or method `’Tools’’ for main:Object>
:in `' -e:1:in `eval' nil
Second line
require “digest/sha2”
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require’
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/digest/sha2.rb:13:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require’
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require’
:in `' -e:1:in `eval' nil Sketchup.find_support_file(’Tools’) Error: # :in `' -e:1:in `eval' nil require "digest/sha2" Error: # C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/digest/sha2.rb:13:in `' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require' :in `' -e:1:in `eval' nil
Third Line
puts $:.inspect
[“C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib”, “C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific”, “C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools”, “C:/Users/Josh/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins”, “C:/Users/Josh”]
nil
Fourth Line
File.exists?(File.join(Sketchup.find_support_file(“Tools”), “RubyStdLib/platform_specific/digest/sha2.so”))
true
Fifth Line
require “digest/sha2.so”
Hope this helps.
same problem with SU2014-w7
Erreur de chargement du fichier C:/Users/Laurent/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec/initialize.rb
Error: 127: La procédure spécifiée est introuvable.
  • C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/platform_specific/digest/sha2.so
    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/Laurent/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:67:in block in <top (required)>’
    C:/Users/Laurent/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:30:in gracefully' C:/Users/Laurent/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec/initialize.rb:49:in <top (required)>’
    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load’
    C:/Users/Laurent/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec.rb:38:in register_extension' C:/Users/Laurent/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec.rb:38:in module:PlusSpec’
    C:/Users/Laurent/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec.rb:25:in <module:Rubysketch>' C:/Users/Laurent/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rubysketch_plusspec.rb:24:in <top (required)>’
on SU2013, he also there error “LOADING TOOLS” I still have not received a response from you despite my post.
and my license trial ends tomorrow.
I think buy pluspec but it does not work on SU pro 2013 or 2014
thank you for an answer.
I have had no problem with the 3.1.5 install nor with the updated Plugins’ operation. I am using Windows 7.
Did you install the newest .rb’s.
People still experiencing this error - what version of SketchUp are you running, as shown by Help > About SketchUp? If its less than 14.1.1282, try updating and see if that fixes your issue (and please post the result here).
Hi there, just new to the forum and a new user of Pluspec, first post actually! Just downloaded the trail version and have an error saying "Error Loading File rubysketch_plusspec/initialize.rb
Could not find included file ‘rubysketch_plusspec/initialize.rb’. Any suggestions on what I need to do to get going.
Sorry, we had an issue uploading - if you re-download and re-install the issue should resolve itself.
