Trying to edit a 1200 high sliding/gliding window to 1800 high. I hit submit and Outliner tray starts flashing for 30 secs, plusspec goes into not responding and just hangs. re-start sketchup. repeat. happens again
everytime i add a window, sketchup goes to not responding for 20 secs before fixing itself and installing window.
We strongly recommend to always have the Outliner closed until it’s really needed as it’s always checking your model and updating itself whenever there’s an update, which slows your computer down.
Would you be able to please let me know if this fixes the issue yo’re having?
When i attempt to modify a window or door, the Plus Spc dialog box takes forever to load all parameters. I also attempted to use the Command Key to select more than one window to edit and that does not work. (Mac)
